Select entities on drawing view by rectangle
is it possible to SelectSet.AddByRectangle (x1,y1,x2,y2)
or something similar?
Thanks in advance, best regards
Massimo
Re: Select entities on drawing view by rectangle
Hello @MassimoMagris
This discussion has some hints.
Tushar
