SelectSet problem in draft
Hi all, I need to select all items in a sheet, move them and finally delete a block and his occurrences.
This is the code I use to move objects:
SolidEdgeFramework.SelectSet selectSet = this.draftDocument.SelectSet;
selectSet.RemoveAll();
selectSet.AddAll();
this.draftDocument.ActiveSheet.MoveSelectSet(xFrom, yFrom, xTo, yTo);
After that, if I try to delete the group manually or programmatically, the deletion time is about 5 minutes.
If I select all manually, instead of programmatically, the deletion time is about 2 or 3 seconds.
Could you help me to solve my time problem?
Thanks in advance
Massimo
