SelectSetChangedEvent with Synchronous Part
Hi
I'm trying to get the selected feature of a synchronous part (see attached image).
I wrote this code (C#):
SolidEdgeFramework.ISEDocumentEvents_Event docEvents = (SolidEdgeFramework.ISEDocumentEvents_Event) document.DocumentEvents;
docEvents.SelectSetChanged += new SolidEdgeFramework.ISEDocumentEvents_SelectSetChangedEventHandle(SelectSetChanged);
private void SelectSetChanged(object SelectSet)
  SolidEdgeFramework.SelectSet s = (SolidEdgeFramework.SelectSet)SelectSet;
  int count = s.Count;
  if (count != 1) return;
  object obj = s.Item(1);
The problem is that when the user selects a feature in SolidEdge, the SelectSet.Count is always 0.
The same code works fine for traditional parts.
Any help will be appreciated.
Thanx
Adar
Posted by: Adar Shtainhart
Post date: 2/1/2009 2:13:26 AM
RE: SelectSetChangedEvent with Synchronous Part
Adar,
I have confirmed what you're seeing and I believe you have found a geniune bug. To be honest, I'm not surprised at all. The Synchronous API is very much in its infancy stage. Your best bet is to log an IR with GTAC to make sure they know about the problem.
Posted by: Jason Newell
Post date: 2/4/2009 5:15:33 PM
Adar,
I just realized that you do have a workaround.  During the SelectSetChanged event, go and get the Application->ActiveSelectSet.  It has the Items correctly populated.
Post date: 2/4/2009 5:17:15 PM
Hi Jason
Thank you very much for your answers.
I tried your workaround suggestion but it didn't work either.
SolidEdgeFramework.SelectSet s = (SolidEdgeFramework.SelectSet)m_application.ActiveSelectSet;
but still the count is zero so I can't use "object obj = s.Item(1);" to get the feature selected.
Thanx
Adar
Post date: 2/8/2009 2:13:20 AM
Could be difference in our service packs or just an overall incomplete implentation. i.e. Maybe some selected objects get updated and others don't. (Guessing)
You still need to file an IR with GTAC to make sure it gets fixed.
Post date: 2/9/2009 11:27:42 AM
Hi Jason
As you suggested, I opened an IR a week ago and I see they changed its status to "Closed as PR" (Problem Report).
My installed version is 100.00.00.133
Is yours different?
Thanx
Adar
Post date: 2/15/2009 1:11:52 AM
Supposedly fixed in Solid Edge ST - Maintenance Pack 6
===API===
PR 6098711: SelectSetChanged events not being fired properly from select tool in Synchronous
Post date: 4/24/2009 8:06:20 AM
