Selecting part's hole feature in Assembly?
I'm trying to create something similar to the 'Inquire Element' function for holes. But I need to (while in assembly mode) select as hole's ID, and it return the diameter (exactly like Inquire Element). Im sure I can get something to find the holes dia. But Im not sure how to switch SE to allow for selection of a hole.
P.S. - being able to select the entire hole feature would be great! But I'd settle for selecting the ID surface of the hole.
Any Ideas?
Thanks!
-Dave
Posted by: David Van Doren
Post date: 9/25/2013 2:28:50 PM
3 REPLIES 3
To those curious, I've found it out, how-ever not ideal.
I objApplication.StartCommand(10779). This switches the select tool to "Face Priority". Then I loop while selectset.count = 0 then throw a DoEvents in between. This keeps my program occupied while the user selects the hole they want. Now the better way is to use EventHandlers for this, but without a working proof of concept, I'm too lazy to set those up.
If someone has a better way, I could sure use it!
Thanks!
Post date: 9/26/2013 5:15:31 PM
I have encountered this problem! Smiley Sad
I hope to find a good way!
Posted by: fat kids
Post date: 10/9/2013 10:47:49 AM
fat kids- what was it you were having trouble with. I've solved this issue, so maybe I can help you out with what youre stuck on.
Post date: 10/9/2013 10:52:39 AM
