SetActionInRevisionManager problem
Hello, I'm trying to change a connection between a dft file to a psm file. (It's already connected to a psm file, I just want to replace it).
I'm trying to use it through the code -
var RevApplication = new RevisionManager.Application();
RevisionManager.Document doc = RevApplication.Open(path);
RevApplication.SetActionForAllFilesInRevisionManager(RevisionManagerAction.ReplaceAllAction, @"D:\directory\filename.psm");
RevApplication.PerformActionInRevisionManager();
RevApplication.Quit();
unfortunately nothing happens.
How am I supposed to change the connection between the dft file and the related psm? What am I doing wrong?
Thanks.
Re: SetActionInRevisionManager problem
You should try something like this, it works for me :
     Public Sub Change_DFT_Source(ByVal DFTFile As String, ByVal OldSourceFile As String, ByVal NewSourceFile As String)
        Dim ObjApp As RevisionManager.Application
        Dim ObjDocument As RevisionManager.Document
        Dim ObjLinkedDocuments As RevisionManager.LinkedDocuments
        ObjApp = CreateObject("RevisionManager.Application")
        ObjDocument = ObjApp.OpenFileInRevisionManager(DFTFile)
        ObjLinkedDocuments = ObjDocument.LinkedDocuments(RevisionManager.LinkTypeConstants.seLinkTypeAll)
        For Each ObjOcc In ObjLinkedDocuments
            If ObjOcc.fullname = OldSourceFile Then
                ObjOcc.Replace(NewSourceFile)
            End If
        Next
        ObjApp.PerformActionInRevisionManager()
    End Sub
Romuald BERTIN
