Sheet Metal Gage Properties: how to read from API
Hallo everyone, I'am looking for a way to read the sheet metal gage property via API.
In SolidEdge.FileProperties I can find material name, but not the sheet metal gage description.
Opening the sheet metal file with an editor, I can find the sheet metal gage description, but I can not locate easily with a program.
Have you some suggest?
Thank you in advance
Stefano
Posted by: stefano soldi
Post date: 2/11/2013 2:48:49 PM
FYI strange behave!
I found the solution! With this simple macro in Excell I found that the property I want is called with the italian name. Smiley Sad
But still something strange, if I change the prop in Solid Edge and save the document, the name of the prop (.name) will be erased "", but the value (.Value) is correct.
Then when I close and reopen the document, again I can find the .Name as usual.
For intI = 1 To objProp.Count
For intI1 = 1 To objProp.Item(intI).Count
riga% = riga% + 1
Sheets(1).Cells(riga%, 1) = objProp.Item(intI).Item(intI1).Name
Sheets(1).Cells(riga%, 2) = objProp.Item(intI).Item(intI1).Value
Next
Next
Post date: 2/12/2013 5:29:13 AM
Sorry! Last post without the end ...
SE ST5 MP2 64 bit on W7 SP1
Stefano
Post date: 2/12/2013 5:39:50 AM
