Sheet Number?
I can easily get the number of sheets by using:
objApp.ActiveDocument.Sections.WorkingSection.Sheets.Count
But, I cannot find a way to extract the current sheet number. Within SE, you can simply use property text, such as:
SHEET %{Sheet number} OF %{Number of Sheets}
Is it possible to easily extract the current sheet number in VB6? What am I missing?
Posted by: Bill Ledbetter
Post date: 9/23/2009 7:03:44 AM
RE: Sheet Number?
Dim ct As Integer
Dim Sht As SolidEdgeDraft.Sheet
For Each Sht In seDraft.ActiveSection.Sheets
ct = ct + 1
If seDraft.ActiveSheet.Name = Sht.Name Then
Exit For
End If
Next
.SheetNum.Caption = "SHEET " & ct & " OF " & seDraft.Sections.WorkingSection.Sheets.Count
Got a work around anyway. Thanks to Grant Holohan.
Post date: 9/24/2009 2:29:14 AM
