Sheet Size...?
Dear All,
I am trying to change the sheet size from A2 to A0 or vice-versa. But it is not getting changed.Sheet size is changing but borders not getting update, this means i have to change the background sheet to A0 or A2. But i am not able to code it or i am not able to active the backgroud sheet thru coding.
Anybode has any idea? I am trying following  but nothing is working
ObjDft = ObjApp.Documents.Open(DFT_File)
        ObjDft = ObjApp.ActiveDocument
        ObjApp.DisplayAlerts = False
        ObjDft.Activate()
        'objSheet = ObjDft.ActiveSheet
        objSheet = ObjDft.Sheets.Item(1)
        '------ Trial --------------------------------------
objSheet.SheetSetup.SheetSizeOption = SolidEdgeDraft.PaperSizeConstants.igIsoA0Wide
OR
objSheet.BackgroundVisible = True
objSheet.Background.SheetSetup.SheetSizeOption=SolidEdgeDraft.PaperSizeConstants.igIsoA0Wide
Posted by: Prasad Pawar
Post date: 6/1/2008 9:17:03 PM
RE: Sheet Size...?
Prasad,  try this:
 lv_sheet = draftDoc.Sections.WorkingSection.Sheets.Item(1);
 lv_sheet.Activate();
 lv_sheet.SheetSetup.SheetSizeOption = PaperSizeConstants.igIsoA2TalligIsoA0Wide;
hth,
Sibi
Posted by: Seb Sosna
Post date: 6/6/2008 11:05:28 PM
RE: Sheet Size...?
You need to set the background of your sheet
workingsheet.Background = backgroundsheet
where backgroundsheet is a reference to the actual background sheet.
I would create a function/sub to copy all of the background sheet setup e.g. DefaultDrawingViewScaleOption, PaperUnits, SheetSizeOption,etc to your working sheet. Sorry but I can't post my code to do this.
hth,
James
Posted by: James Singleton
Post date: 6/12/2008 7:54:25 AM
RE: Sheet Size...?
'Dear Prasad i have written this code in VB.NET just try it works fine, if not then send reply me i will try to give a live code
Public objSheets As SolidEdgeDraft.Sheets
Public objSheet As SolidEdgeDraft.Sheet
Public backSheet As SolidEdgeDraft.Sheet
For Each objSheet In objSheets
cmbbgSheet.Items.Add(objSheet.Name) 'Add to combo box
Next
'on event of cmbSheets_SelectedIndexChanged write following code
If (cmbSheets.Text = objSheet.Name) Then
backSheet = objSheet.Background
End If
Next
'CmdSetBgSheet_Click on write following code
For Each backSheet In objSheets
If (cmbbgSheet.Text = backSheet.Name) Then
objSheet.Background = backSheet
backSheetstr = backSheet.Name
objSheet.SheetSetup.SheetHeight = backSheet.SheetSetup.SheetHeight
objSheet.SheetSetup.SheetWidth = backSheet.SheetSetup.SheetWidth
objDraft.Save()
Exit For
End If
Next
Posted by: Sandeep Shewale
Post date: 6/12/2008 10:51:45 PM
RE: Sheet Size...?
Next
End If
Next
objDraft.Save()
Exit For
End If
Next
Post date: 6/12/2008 10:53:04 PM
RE: Sheet Size...?
Dear all,
i tried this code but don't run.
Have you a solution ?
Posted by: Filippo Colonna
Post date: 5/1/2011 9:26:35 PM
