Sheet settings
Hello All,
How to set the origin of a drawing sheet in SolidEdge ST3 through Vb.net program to the center of the screen.
Also how to change the unit to inches from mm through vb.net program.
Please help.
Thank You
Posted by: Shruthi M
Post date: 5/16/2013 4:49:10 AM
Sheet settings
When you mean change mm to inch, are you referring to the placed dimensions?
And Im not sure what you mean by 'set the origin'. When does this matter?
Posted by: David Van Doren
Post date: 5/16/2013 8:00:59 AM
Sheet settings
You have to give SE the dimensions in Meters. Do the math then convert to meters. You know your sheet size, you can query the size of the view. You can also set the origin of the view.
Posted by: Terry Tyson
Post date: 5/17/2013 9:52:48 AM
