Show/Hide specific Occurrences in an Assembly.asm File
I am driving an animation of a Solid Edge Assembly file using Visual Basic driven by an Excel Spreadsheet.  I need the ability to hide or show very specific occurrences of the first level of the BOM from time to time.  I may have 5 occurrences of an Component1.asm in an assembly file.  Is there a way to grab the Placement Name of the third instance, ie: Component1.asm:3, of the top level and choose to show or not show it?
I have a working animation where I am driving variables inside Solid Edge to produce motion, but I am having trouble trying to show or hide very specific components at specific animation movement locations.
Example: Simple assembly file structure.
Project.asm
   Component1.asm:1
   Component1.asm:2
   Par1.par:1
   Par2.par:1
   Component1.asm:3   <==  Hide this one
   Par1.par:2
   Component1.asm:4
Don
Re: Show/Hide specific Occurrences in an Assembly.asm File
Project.asm
   Component1.asm:1
   Component1.asm:2
   Par1.par:1
   Par2.par:1
   Par1.par:2
   Component1.asm:4
Don
You should be able to use the Name property on the Assembly Occurrence object:
Dim Occurrence as SolidEdgeAssembly.Occurrence
Dim Name as String
'get the occurrence somehow
Name = Occurrence.Name
This is just a rough little snippet, but should show at least the basics to get the name.
Hope this helps,
Greg
