Show Model Sketches and Referenceplanes in Drawingview
How to show Model Sketches and Referenceplanes in a Drawingview by API?
Kind Regards Marthijn
Re: Show Model Sketches and Referenceplanes in Drawingview
If you want to show all reference planes and model sketches in a drawing view, you have to make their corresponding model members visible.
The following code shows all sketches and reference planes in all drawing views on the active sheet:
    ' DFT: Show all sketches and reference planes in all drawing views
    Dim objDoc As SolidEdgeDraft.DraftDocument = objApp.ActiveDocument
    Dim objSheet As SolidEdgeDraft.Sheet = objDoc.ActiveSheet
    For Each objDrawView As DrawingView In objSheet.DrawingViews
      ' As the drawing was generated from a Part document, only one ModelMember for the document exists
      Dim objDocMember As ModelMember = objDrawView.ModelMembers.Item(1)
      For Each objMember As ModelMember In objDocMember.ModelMembers
        If objMember.ComponentType = ModelMemberComponentTypeConstants.seReferencePlaneMemberType OrElse _
           objMember.ComponentType = ModelMemberComponentTypeConstants.seSketchMemberType Then
          objMember.DisplayType = ModelMemberDisplayTypeConstants.seShowPart
        End If
      Next
      objDrawView.Update()
    Next
Thanks for your help Martin Bernard!
