Show and hide groups
I have been asked to write a VB6 program to show and hide groups in a 2D model view. How do I select the group to show/hide
Posted by: Paul Collins
Post date: 5/8/2009 12:09:33 AM
RE: Show and hide groups
Do you mean select it interactively with your mouse?
If not, you just can access through the Groups collection in your sheet:
set myGroup = oSE.ActiveDocument.ActiveSheet.Groups.item()
To hide or show it:
myGroup.Visible= True or False
Or playing with Layers:
myGroup.Layer="LayerName" 'This will move the group to that layer. If the layer is visible or not, the group will be.
Posted by: Julian Guillo
Post date: 5/10/2009 11:57:01 PM
Thanks for this info. I'll try it out.
Post date: 5/11/2009 12:00:17 AM
It worked but I also need to select groups within a group. I've tried playing about with the code but with no luck. Any ideas, please.
Post date: 5/12/2009 1:58:46 AM
What do you need to do exactly? I might help, but i would like to have a global idea about your objective...
Post date: 5/13/2009 5:07:28 AM
Julian
I have just managed to sort it out. I was trying to select a group which was nested in another group (child/parent relationship). All it needed was another .Item() after the first one.
Once again, many thanks for your help - it set me on the right path.
Post date: 5/13/2009 5:13:45 AM
