Small question, check if property exists.
When i check all the properties of the part, i want to check if there is a value, and when this value doesn't exists I want to add the custom property.
The macro does a check every time in a loop, then the next row and so on. So how can I put a overall check? Something like "If after the last loop still "value" = nothing then add .....
You would really help me with this.
 For i As Integer = 1 To Main.SEDocumentPropertySets.Count
            Main.SEDocumentProperties = Main.SEDocumentPropertySets.Item(i)
            For j As Integer = 1 To Main.SEDocumentProperties.Count
                Main.SEDocumentProperty = Main.SEDocumentProperties.Item(j)
 If Main.SEDocumentProperty.Name = "Aantal" Then
                    Main.SEDocumentProperty.Value = TextBox_Aantal.Text
End If
      Next
        Next
Re: Small question, check if property exists.
you could use
If String.IsNullOrEmpty(Cstr(Main.SEDocumentProperty.Value)) then
   ' Add value
EndIf
to check for a non empty value.
If you want check whether your property exists at all you could use
Dim propertyFound as Boolean = False
' Outer loop for PropertySets
For ...
   ' Inner loop for Properties
   For ...
         propertyFound = True
         ' Set its value
    Next
Next
If Not propertyFound then
   ' Add property
EndIf
Kind regards,
Wolfgang Kunert - www.wksyspro.de
It doesn't work. This code adds the value when it exists but does not create it of gives the messagebox...
                If Main.SEDocumentProperty.Name = "Subject" Then
                    Main.SEDocumentProperty.Value = ComboBox_Ondertitel.Text
                End If
                If Main.SEDocumentProperty.Name = "Klant" Then
                    Main.SEDocumentProperty.Value = ComboBox_Klant.Text
                End If
                If String.IsNullOrEmpty("aantal") Then
                    'MsgBox("test")
                    'Form_InfoNoApplication.Show()
                    Main.SEDocumentProperties.Add("Aantal", TextBox_Aantal.Text)
                                 Else
                    End If
                End If
            Next
        Next
Dim propAantalFound as Boolean = False
                End If
                End If
                        propAantalFound = True
                    End If
                End If
            Next
        Next
If Not propAantalFound Then
   Main.SEDocumentPropertySets("Custom").Add("Aantal", TextBox_Aantal.Text)
EndIf
Kind regards,
