Solid Edge API Developer - Openings in Bangalore
Hello Edgers:
Krones India has openings for Solid Edge API developers.
Minimum 3 years relevant experience is required for this role.
The position is based in Bangalore.
If you are interested in taking up this job, please send resumes to Tushar.Suradkar@krones.in
Please see the Job Description attached.
Thanks.
Tushar Suradkar
