Solid Edge Addin release
hello,
I developped a solid edge addin..
so i want know all my collegue in work uses my add-in.so when i'm running the registration bat file(attached), I get this warnning
RegAsm : warning RA0000: Registering an unsigned assembly with /codebase can cause your assembly to interfere with other applications that may be installed on the same computer. The /codebase switch is intended to be used only with signed assemblies. Please give your assembly a strong name and re-register it.
what should i do exactly?
is there a proper signture tools ?
Re: Solid Edge Addin release
PLM World Member Pioneer PLM World Member Pioneer
Here is the MSDN article for signing your assembly with a strong name:
https://msdn.microsoft.com/en-us/library/xc31ft41%28v=vs.110%29.aspx
Nate Emler
Nate Emler
Engineering Programmer
Ariel Corporation
