Solid Edge Assembly API Tutorials
Can someone share link to SE assembly API tutorials ? Thanks.
Re: Solid Edge Assembly API Tutorials
What kind of task do you wish to accomplish using the Assembly API.
Here are a few samples to help you learn the Assembly API:
https://github.com/SolidEdgeCommunity/Samples/tree/master/Assembly
Thanks Tushar. I am trying to mate new component by distance mate with existing component. The code is as follows for co-incident mate, but I want to add distance mate. Can you help ?
Private Sub btnTestSePlnrDistMate_Click(sender As Object, e As EventArgs) Handles btnTestSePlnrDistMate.Click
Dim oapp As SolidEdgeFramework.Application
Dim odocs As SolidEdgeFramework.Documents
Dim odoc As SolidEdgeDocument
Dim oasm As SolidEdgeAssembly.AssemblyDocument
Dim opart As SolidEdgePart.PartDocument
Dim opartp As SolidEdgePart.PartDocument
Dim ooccu As SolidEdgeAssembly.Occurrence
Dim ooccup As SolidEdgeAssembly.Occurrence
Dim prefpl, crefpl As SolidEdgePart.RefPlane
Dim orel3d As Reference
Dim orel3d2 As Reference
Dim firstrel As SolidEdgeAssembly.PlanarRelation3d
Dim ogroundrel As SolidEdgeAssembly.GroundRelation3d
Dim arrDou1 As Array
Dim arrDou2 As Array
Dim cref, pref As String
Try
oapp = Marshal.GetActiveObject("SolidEdge.Application")
oapp.Visible = True
Catch ex As Exception
End Try
If oapp Is Nothing Then
Dim acType As Type = Type.GetTypeFromProgID("SolidEdge.Application")
oapp = CType(Activator.CreateInstance(acType, True), SolidEdgeFramework.Application)
oapp.Visible = True
End If
odocs = oapp.Documents
For i = 0 To odocs.Count - 1
odoc = odocs(i)
odoc.Close(True)
Next
Dim AsmPath = txtAsmPath.Text
Dim ParentNameWithExt = txtParentNamewithExt.Text
Dim ChildPath = txtChildPath.Text
oapp.Documents.Open(AsmPath)
oasm = oapp.ActiveDocument
Dim ooccus As SolidEdgeAssembly.Occurrences
ooccus = oasm.Occurrences
ooccu = ooccus.AddByFilename(ChildPath)
For j = 1 To oasm.Occurrences.Count
Dim CurOccName As String = oasm.Occurrences.Item(j).Name
If CurOccName.Substring(0, CurOccName.LastIndexOf(":")) = ParentNameWithExt Then
ooccup = oasm.Occurrences.Item(j)
Exit For
End If
Next
opart = ooccu.OccurrenceDocument
opartp = ooccup.OccurrenceDocument
cref = "Front (xz)"
pref = "Front (xz)"
For j = 1 To opartp.RefPlanes.Count - 1
If opartp.RefPlanes.Item(j).EdgebarName = pref Then
prefpl = opartp.RefPlanes.Item(j)
End If
Next
For j = 1 To opart.RefPlanes.Count - 2
If opart.RefPlanes.Item(j).EdgebarName = cref Then
crefpl = opart.RefPlanes.Item(j)
End If
Next
orel3d = oasm.CreateReference(ooccup, prefpl)
orel3d2 = oasm.CreateReference(ooccu, crefpl)
ogroundrel = oasm.Relations3d.Item(2)
Call ogroundrel.Delete()
arrDou1 = Array.CreateInstance(Type.GetType("System.Double"), 3)
arrDou2 = Array.CreateInstance(Type.GetType("System.Double"), 3)
firstrel = oasm.Relations3d.AddPlanar(orel3d, orel3d2, False, arrDou1, arrDou2)
End Sub
