Solid Edge Comand Macro how to use it?
I downloaded the solid edge command macro, containing the mouse events and was wondering if anybody could give me a rundown of what I can do with it to help me in my programming?Or a simple example what can be done with it.
Thanks.
ST9
Conveyor and industrial equipment designer.
Giving SE a chance.
Re: Solid Edge Comand Macro how to use it?
I would like to know as well.
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
A good example can be found on GitHub.
MouseEvents C#
MouseEvents VB
Jason Newell
Applications Architect
www.jasonnewell.net
