Solid-Edge Customization Material......
Hi All,
As I am new to solid Edge customization.I am facing some problems.
I need some reference materials or some sample programs that would help me.
So, from where I can get these stuffs.
Please give  links or web site names.
Hemant
Posted by: Hemant Pawar
Post date: 8/12/2008 6:59:40 PM
RE: Solid-Edge Customization Material......
Hemant,
1) You can access SDK examples files where you have installed SE (\\Program Files\Solid Edge vXX\SDK).
2) There are some default programs provided by UGS, you can find them at: \\Program Files\Solid Edge vXX\Custom
Posted by: Prasad Pawar
Post date: 8/12/2008 8:42:12 PM
Thanks Prasad !I will go through it.
Post date: 8/12/2008 8:44:21 PM
Hemant,
I recommend that you modify your orignal post and remove your email address.  I discourage people putting their email directly in posts because it exposes your address to spammers.  People can send you email by clicking on your name from the forums.  This approach masks (hides) your actual address.
I can remove it but I didn't want to be rude.
Posted by: Jason Newell
Post date: 8/12/2008 8:48:34 PM
I think what Jason is saying is right.
You can share your queries directly on the forum, this would be better.
Post date: 8/12/2008 8:53:26 PM
Posted By prasad on 08/13/2008 1:53 AM
Just for the record, I don't mind direct communication at all.  I just wanted to point out that it's safer to click the users name which takes you to their profile.  From there, you can click the "Click to Send Email" link to send private messages.
Post date: 8/12/2008 8:57:44 PM
Yes,you are right.
I will prefer to post queries directly on forum. I changed my topic containts.
Hemant
Post date: 8/12/2008 9:01:26 PM
Also check out the Solid Edge Downloads page.
That page contains Devloper Conference material that I used when I spoke at previous years conferences.
Post date: 8/12/2008 9:11:48 PM
