Solid Edge Embedded Client API
Before Teamcenter Express, I was able to add a part to an assembly by using Occurrences.AddByFilename.
Can I still use this, if so what do I give it for a path? Otherwise, is there
some other command I can use instead? I have programs that allow users to insert
common parts into their assemblies. These parts and assemblies are now in TcX,
so I need to update my programs.
Posted by: Kevin Haen
Post date: 3/27/2007 7:46:14 AM
