Solid Edge ST2: how can I get a hole's radius and the center point
Hello All,
I am using SE ST2 and need to read data about a part's hole:
- radius
- center point.
I have a code that worked for SE ST, but it doesn't work in ST2:
Add a new profile set, a new profile and get the 2d object.
How can I retrieve the data in ST2?
I'm working with VC++ 2008.
Thank you,
Vadim
Posted by: Vadim Zlotnikov
Post date: 12/15/2009 1:09:31 AM
