Solid Edge ST5 and Visual Basic 6.0
Is it possible to program Solid Edge ST5 with Visual Baic 6.0?
Posted by: Andries
Post date: 10/29/2012 3:37:11 AM
this might be a problem, because you can't install ST5 on XP anymore and on the other side you can't install VB6 on Windows Vista/7.
As long as you don't need API calls new with ST5 you still might develop against ST4 on XP and use your Exe also with ST5 as long as future Windows version still will support the VB6 runtime.
Posted by: Wolfgang Kunert
Post date: 10/29/2012 6:49:11 AM
out of date but possible.
[url=http://msdn.microsoft.com/en-us/vstudio/ms788708]Support vb6[/url]
Gerald
Posted by: Gerald Haberl
Post date: 10/29/2012 7:18:50 AM
Okay, thanks alot!
Posted by: Andries
Post date: 10/29/2012 8:16:44 AM
