Solid Edge ST6 API - Help with saving four faces of a part to pdf
I have a .NET program that saves part files as 3d pdfs or as plain pdfs with a default isometric view. This was simple enough, but I was wondering if it is possible to save the bottom, top, left, and right right views to a single page. If not, how would I go about saving each face to its own page in a pdf? I have been scouring the Solid Edge API documentation but figured I should ask for help going about this. If anyone could point me in the right direction I would appreciate it.
Re: Solid Edge ST6 API - Help with saving four faces of a part to pdf
Using the Application.StartCommand() method passing one of the following arguments will get your view to change.
SolidEdgeConstants.PartCommandConstants.PartViewBackView
SolidEdgeConstants.PartCommandConstants.PartViewFrontView
SolidEdgeConstants.PartCommandConstants.PartViewTopView
SolidEdgeConstants.PartCommandConstants.PartViewBottomView
SolidEdgeConstants.PartCommandConstants.PartViewLeftView
SolidEdgeConstants.PartCommandConstants.PartViewRightView
As you said, you'll have to save each one of these out to their own PDF and combine using some other means.
Jason Newell
Solutions Architect
www.jasonnewell.net
