Solid Edge View Manipulation
Has anyone figured out how to program view changes in SolidEdge.
I've got a basic way by sending an arrow key using sendkeys but it's a bit flaky.
My aim ....
Start with the view (front for example). Rotate 90deg left in 15deg increments ?(take a snapshot at each stage) then zoom in on a part.
I can then piece the snapshots together to make a movie.
Many Thanks
Cameron
Posted by: Cameron Smith
Post date: 2/6/2006 9:34:49 AM
RE: Solid Edge View Manipulation
I think that I have the code that you need at home. I'll hook you up when I get off work.
Posted by: Jason Newell
Post date: 2/6/2006 9:43:43 AM
Take a look at this quick demo I whipped together. Let me know if you need anything else.
Post date: 2/7/2006 1:42:19 AM
Where can I look this demo?
Posted by: Andrus Isotamm
Post date: 10/7/2007 7:15:11 AM
Andrus,
The file got lost during my last website migration.  Luckily, I had a backup.  Here it is.
Post date: 10/17/2007 6:32:00 PM
Thanks.
Post date: 10/18/2007 12:45:46 AM
