Solid Edge Windows 10 support
Hello guys, my addin has an issue on WIndows 10, whenever the program executes "saveas(.....stl)" its throws a com error. it works perfectly fine on win7 and win8. Does someone have an idea?
manually exporting (through GUI) works.
Re: Solid Edge Windows 10 support
Just tested the STL conversion with one of my programs with ST8 (64) on Windows 10 Pro (64). There seems to be no general problem at least with ST8.
Kind regards,
Wolfgang Kunert - www.wksyspro.de
Did you convert with the GUI manually or autonomyous with the method saveAs("filename.stl") ?
Because I am having issues with the second, the first works with my solid edge too!
As i've written, with one of my programs (using SaveAs()).
Kind regards,
