Solid Edge macro doest do anything.
Im trying to make a visual basic console application for Solid Edge, in this console application i want visual basic to make curves in Solid Edge. These curves had data stored in a space dilimited text file. I tried to make the program but it got stuck at making the lines, the console just stays blck and there's just an opened part file.
Does anyone knows what i'm doing wrong, or what i should do? I'm using visual basic 2003 standart, and i am trying this with Solid Edge ST2.
I'm not a programmer, so help i much appriciated.
Heres my code: ( I made this code with stuff i found on the internet, form the solid edge programmers guide and made some by my self.
[code]Imports System.IO
Imports System.Runtime.InteropServices
Module Module1
Sub Main()
Dim strFileName As String = "U:\pompen.prn"
Dim objFS As New FileStream(strFileName, FileMode.Open, FileAccess.Read)
Dim objSR As New StreamReader(objFS)
Dim objApp As SolidEdgeFramework.Application = Nothing
Dim objDocuments As SolidEdgeFramework.Documents = Nothing
Dim objPart As SolidEdgePart.PartDocument = Nothing
Dim objProfileSets As SolidEdgePart.ProfileSets = Nothing
Dim objProfileSet As SolidEdgePart.ProfileSet = Nothing
Dim objProfiles As SolidEdgePart.Profiles = Nothing
Dim objProfile As SolidEdgePart.Profile = Nothing
Dim objRefplanes As SolidEdgePart.RefPlanes = Nothing
Dim objdraft2d As SolidEdgeDraft.CoordinateSystem2d = Nothing
Dim objBSpline As SolidEdgeFrameworkSupport.BSplineCurve2d = Nothing
Dim objBSplines As SolidEdgeFrameworkSupport.BSplineCurves2d = Nothing
Dim objLines2d As SolidEdgeFrameworkSupport.Lines2d = Nothing
Dim objLine2d As SolidEdgeFrameworkSupport.Line2d = Nothing
Dim strEmpRecord As String
Dim type As String
Dim N1 As Double
Dim QT As Double
Dim DW1 As Decimal
Dim EQ As Decimal
Dim EH As Decimal
Dim DWL As Decimal
Dim DHL As Decimal
Dim C1 As Decimal
Dim C2 As Decimal
Dim C3 As Decimal
Dim C4 As Decimal
Dim C5 As Decimal
Dim QFACTOR As Decimal
Do While objSR.Peek <> -1
' read the current record (line) into the variable strEmpRecord
strEmpRecord = objSR.ReadLine
' break up the record into separate variables
type = strEmpRecord.Substring(0, 20)
N1 = CDbl(strEmpRecord.Substring(20, 10))
QT = CDbl(strEmpRecord.Substring(30, 10))
DW1 = CDec(strEmpRecord.Substring(40, 10))
EQ = CDec(strEmpRecord.Substring(50, 10))
EH = CDec(strEmpRecord.Substring(60, 10))
DHL = CDec(strEmpRecord.Substring(70, 10))
DWL = CDec(strEmpRecord.Substring(80, 10))
C1 = CDec(strEmpRecord.Substring(90, 20))
C2 = CDec(strEmpRecord.Substring(110, 20))
C3 = CDec(strEmpRecord.Substring(130, 20))
C4 = CDec(strEmpRecord.Substring(150, 20))
C5 = CDec(strEmpRecord.Substring(170, 20))
QFACTOR = CDec(strEmpRecord.Substring(190, 10))
Catch ex As System.InvalidCastException
End Try
'connect to a Solid Edge file.
' Connect to a running instance of Solid Edge
objApp = Marshal.GetActiveObject("SolidEdge.Application")
' Get a reference to the documents collection
objDocuments = objApp.Documents
' Create a new part document
objPart = objDocuments.Add("SolidEdge.PartDocument")
' Get a reference to the profile sets collection
objProfileSets = objPart.ProfileSets
' Add a new profile set
objProfileSet = objProfileSets.Add()
' Get a reference to the profiles collection
objProfiles = objProfileSet.Profiles
' Get a reference to the ref planes collection
objRefplanes = objPart.RefPlanes
' Add a new profile
objProfile = objProfiles.Add(objRefplanes.Item(3))
'Gat a reference to spline curve collection
objBSplines = objProfile.BSplineCurves2d
' Get a reference to the lines2d collection
objLines2d = objProfile.Lines2d
'Draw the curves with 4th degree equation, DMax
Dim q As Decimal = (QT * 0.2)
Dim h As Decimal = (((q ^ 4) * C1) + ((q ^ 3) * C2) + ((q ^ 2) * C3) + (q * C4) + C5)
q = (q + 0.5)
Loop Until q <= (QT * QFACTOR)
objBSpline = objBSplines.objsr.AddByPoints(q, h, q, h)
'Draw the curves with 4th degree equation, DMin
Dim qx As Decimal = ((DWL / DW1) ^ EQ)
Dim hx As Decimal = ((DWL / DW1) ^ EH)
Dim qa As Decimal = (qx * q)
Dim ha As Decimal = (hx * (((q ^ 4) * C1) + ((q ^ 3) * C2) + ((q ^ 2) * C3) + (q * C4) + C5))
qa = (qa + 0.5)
Loop Until qa = (qx * (QT * QFACTOR))
objBSpline = objBSplines.objsr.addbypoints(qa, ha, qa, ha)
'make connection lines
objLine2d = objLines2d.AddBy2Points((qx * (QT * QFACTOR)), (QFACTOR * (hx * (((q ^ 4) * C1) + ((q ^ 3) * C2) + ((q ^ 2) * C3) + (q * C4) + C5))), (QT * QFACTOR), (QFACTOR * (((q ^ 4) * C1) + ((q ^ 3) * C2) + ((q ^ 2) * C3) + (q * C4) + C5)))
' Close the profile
objProfile.End( _
Catch ex As Exception
If Not (objLine2d Is Nothing) Then
objLine2d = Nothing
End If
If Not (objLines2d Is Nothing) Then
objLines2d = Nothing
End If
If Not (objBSpline Is Nothing) Then
objBSpline = Nothing
End If
If Not (objRefplanes Is Nothing) Then
objRefplanes = Nothing
End If
If Not (objProfile Is Nothing) Then
objProfile = Nothing
End If
If Not (objProfiles Is Nothing) Then
objProfiles = Nothing
End If
If Not (objProfileSet Is Nothing) Then
objProfileSet = Nothing
End If
If Not (objProfileSets Is Nothing) Then
objProfileSets = Nothing
End If
If Not (objPart Is Nothing) Then
objPart = Nothing
End If
If Not (objDocuments Is Nothing) Then
objDocuments = Nothing
End If
If Not (objApp Is Nothing) Then
objApp = Nothing
End If
End Try
Console.WriteLine("Press Enter to close this window.")
End Sub
End Module[/code]
Posted by: Andries
Post date: 11/14/2012 8:04:20 AM
