Reply
SolidEdge ST : Missing OccurrenceDocument.Properties??
[ Edited ]
HI,
I was trying to extract BOM from assembly, with an example os SolidEdge conference 2005.
- Windows Vista
-Visual Studio 2005
-SolidEdge ST MP3
It seems that .OccurrenceDocument.Properties is no longer availble.
1. Is correct?
2. Where I can get the properties of an OccurrenceDocument?
Thanks in advance for any info.
Best Regards
Massimo
objPropertySets = objOccurrence.OccurrenceDocument.Properties
Dim objOccurrence As SolidEdgeAssembly.OccurrenceDim objPropertySets As SolidEdgeFramework.PropertySetsDim objProperties As SolidEdgeFramework.PropertiesDim objChildNode As TreeNodeDim objListViewItem As ListViewItemDim i AsInteger
 ' Loop through the occurrences
objOccurrence = objOccurrences.Item(i)
objChildNode = objNode.Nodes.Add(objOccurrence.Name)
objChildNode.Tag = objOccurrence
 For i = 1 To objOccurrences.Count' Get some file properties
objProperties = objPropertySets.Item(
 "ProjectInformation")' Add a ListViewItem representing this occurrence
objListViewItem =
.SubItems.Add(objOccurrence.Name)
.SubItems.Add(objProperties.Item(
.SubItems.Add(objOccurrence.Quantity)
.SubItems.Add(objOccurrence.OccurrenceFileName)
.Tag = objChildNode
 Me.lvBOM.Items.Add(level)With objListViewItem"Document Number").Value)"Revision").Value)EndWith
 ' Check to see if this occurrence has suboccurrences
 If (objOccurrence.Subassembly = False) Then
objChildNode.ImageIndex = 2
objChildNode.SelectedImageIndex = objChildNode.ImageIndex
 Else
objChildNode.ImageIndex = 3
LoadOccurrences(objChildNode, objOccurrence.OccurrenceDocument.Occurrences, level + 1)
 EndIf
 Next
 EndSub
Posted by: Massimo Magris
Post date: 1/31/2009 5:01:24 AM
RE: SolidEdge ST : Missing OccurrenceDocument.Properties??
[ Edited ]
Massimo,
Everything seems ok on my machine. What problem\error are you having exactly?
Posted by: Jason Newell
Post date: 1/31/2009 3:38:24 PM
