SolidEdgeDraft.Blocks Properties
Can someone tell me if there is a way to access (set and get) the items from the properties array you see when you open the properties window of a SolidEdgeDraft.Block ?
Using C#, but VB is fine too.
Matt
Posted by: Matt Gabbard
Post date: 9/4/2013 8:40:55 AM
Matt,
out of brain you should find the block properties (called block labels) as follows:
DraftDocument.Blocks
->BlockOccurrences
-->BlockOccurrence
--->BlockLabelOccurrences
---->BlockLabelOccurrence
---->>BlockLabel
Posted by: Wolfgang Kunert
Post date: 9/4/2013 11:02:07 AM
