SolidEdgeTCE.GetSmartCodes problem
I've been trying to import documents to teamcenter from ever possible entry point and through SolidEdge seems like the least impossible right now. The only problem I have right now is that whenever I call the sub GetSmartCodes SolidEdge crashes. Sometime it says it has to quit due to a lack of memory, but task manager shows almost 7gb available.
I would include my code, but I'm not on my development machine right now and I'm pretty sure that's not the main problem as the same thing happens if I try running the sample code for GetSmartCodes from the documentation.
So does anyone have any experience with this particualr problem or just importing documents to teamcenter in general?
Best regards,
Matic Franko
