SolidEdgeTCE.OnGetWhereUsedForAutomation returning no results
I am not having any luck getting this function to return results.  As it is written in the below link, I get an Invalid callee. (Exception from HRESULT: 0X80020010 (DISP_E_BADCALLEE)).
http://support.industrysoftware.automation.siemens.com/training/se/107/api/SolidEdgeFramework~SolidE...
I tried;
Dim vt as VariantType
Dim vtw As Object = New System.Runtime.InteropServices.VariantWrapper(vt)
and passing vtw.
It gets past the Call to the function but the wrapper contains no results.
I also tried
Dim vt as Object
with the same results.  None.
I can do objSEEC.DoesTeamCenterFileExists and bFileExists = true so I know it is connecting and finding the file but returning no results.  I know the file is used in an SE assembly.
Re: SolidEdgeTCE.OnGetWhereUsedForAutomation returning no results
I was passing Dataset Name and not Dataset File Name.
