Solidedge Programming / API
Can any one share one small programme / Code of tube sketch using VB.Net ?
I'm not sure off hand if I have an example but I will see...
I'm not sure off hand if I have an example but I will see what I can do to produce one. Be sure and check out http://solidedgesamples.codeplex.com for examples. I will reply if I come up with anything.
Jason Newell
Applications Architect
www.jasonnewell.net
Re: I'm not sure off hand if I have an example but I will see...
Esteemed Contributor
Jason, do you have something for this yet?
Production: ST9 MP10
Testing: ST10 MP3
No Not yet Jason, but i would like to know, also i would request you to please suggest me for which programming language training , i should go for solidedge.
Hi there Jason,
I have drawn one sketch in part file, for tube. If you can help me out to write a programme
for the same sketch. so that i can know more about the simple sketch Prog. using VB only.
I've asked for an example from an insider but haven't heard back. I'll follow up with them today.
Jason Newell
www.jasonnewell.net
I have attached that example as a prt file (Inside Sketch) . It is reflecting in the question dialogue box.
Hi Jason,
I didnt find any answer for This thread.
Any program or hint for "sketch selection" in tube creation(XpresRoute)
Bala.
I'm trying this too!
With the examples of github i've managed to extrude one profile but only massive. If i try to giv it a thickness, the programm fails. If i have a solution i will tell you!
Please check my sample under this thread.
