Solidedge ST7 drawing file BOM to Excel using VB.Net
Hi Guys,
This is ganesh, I am new for Solidedge Vb.net API programming. I have experience in Vb.net.
Actually, I am looking for Solidedge ST7 drawing file BOM to Excel using VB.Net.
I don’t have any idea and knowledge about this(solidedge API).
Please give me any suggestion and ideas for further process.
Thnks
Ganesh
Re: Solidedge ST7 drawing file BOM to Excel using VB.Net
hi,
Just i tried... its working for me. please try it...
Activate Solidedge Draft & then run this code...
Dim objApp As SolidEdgeFramework.Application
Dim objDraft As SolidEdgeDraft.DraftDocument
Dim objSheet1 As SolidEdgeDraft.Sheet
Dim objpartlts As SolidEdgeDraft.PartsLists
Dim objpartlt As SolidEdgeDraft.PartsList
Dim objpartltscolms As SolidEdgeDraft.TableColumns
Dim objpartltsrows As SolidEdgeDraft.TableRows
Dim objpartcell As SolidEdgeDraft.TableCell
Dim APP As New Excel.Application
Dim worksheet As Excel.Worksheet
Dim workbook As Excel.Workbook
APP.Visible = True
workbook = APP.Workbooks.Open("D:\Temp\12345.xlsx")
worksheet = workbook.Worksheets("sheet1")
objApp = GetObject(, "SolidEdge.Application")
objDraft = objApp.ActiveDocument
objSheet1 = objDraft.ActiveSheet
objpartlts = objDraft.PartsLists
objpartlt = objpartlts.Item(1)
objpartltscolms = objpartlt.Columns
objpartltsrows = objpartlt.Rows
For i = 1 To objpartltscolms.Count - 2
worksheet.Cells(1, i).value = objpartltscolms.Item(i).HeaderRowValue
For J = 1 To objpartltsrows.Count
objpartcell = objpartlt.Cell(i, J)
worksheet.Cells(J + 1, i).value = objpartcell.value
Next
Next
Hi Balamurugan,
Thnks lot for timely help.
I will try out your coding and update you.
Thnks
Ganesh
