StartCommand for an AddIn
Here's what I need to do:
I have an AddIn running in Edge with a command (cmdID = 0). I need to start this command from an external app.
I have managed to get a handle on the AddIn's events but can't get the appropriate ISEAddInEvents interface to call the OnCommand() method.
Any ideas??
Calum
Posted by: Calum McLellan
Post date: 10/24/2006 1:37:34 AM
RE: StartCommand for an AddIn
Calum,
I haven't coded any of this but off the top of my head:
When you call SetAddinInfo(), your command id's are by ref meaning Solid Edge will provide you with a runtime command id. Debug it and watch your command id array. Once you know your runtime command ids, you can invoke them simply by calling objApplication.StartCommand(YourCommandID).
Posted by: Jason Newell
Post date: 10/24/2006 1:45:09 AM
The man knows, the man knows
Post date: 10/24/2006 1:52:48 AM
Hello Jason and Calum,
I get the CommandID (0x00008001) of my Addin Command.
But the parameter "YourCommandID" of objApplication.StartCommand(YourCommandID)must be SolidEdgeFramework:Smiley FrustratedolidEdgeCommandConstants. Can you tell me, how to start this Command?
Posted by: Julia Schneider
Post date: 5/26/2007 11:23:06 PM
Posted By Julia Schneider on 5/27/2007 4:23:05 AM
Julia,
I'm not sure what programming language your using so I can't really show you the exact syntax but you must cast the parameter.
application->StartCommand(SolidEdgeFramwork:Smiley FrustratedolidEdgeCommandConstants)8001);
Post date: 5/27/2007 5:45:30 PM
Post date: 5/27/2007 11:41:28 PM
I have the same questions, and this has got me almost to where I need to be - But, two questions remain:
1. I have found the CommandID for the command in my AddIn that I want to run. - Is this always going to be the same, regardless of machine it is running on?
2. With that, I can call it from another app that has connected to solidedge session using the StartCommand() function. - Is there any way to make that app stop and wait until the command has actually completed, as opposed to immedatly returning? If not, any suggestions / thoughts on some kind of flag I could manually set / check in the SE environment to allow me to know when it had really finished?
Many thanks!
Posted by: chris mann
Post date: 7/3/2007 12:13:58 PM
Posted By chris mann on 07/03/2007 5:13 PM
Many thanks!
Chris,
Sorry for not responding sooner.  I was out on vacation last week.
To answer question #1, you are not guaranteed those command ID's.  They are calculated at runtime.
Question #2 I'll have to spend some time on this week.  Not sure right at this moment.
Post date: 7/8/2007 5:29:40 PM
Jason,
Thanks for the response and hope you had a nice vacation!
#1 - I did find they changed, depending upon the mode (part, assembly, etc...). This is obviously a bit of a nuisance, because it means I have to find it each time my plugin is run, store it somewhere that an external vb app can read (looks like a file to me!) and then read it from there before using it in the vb app.
#2 - If you find / think of a solution please let me know, but don't spend too much time on it. For the moment, I have had to go the route of waiting for output files to arrive from the plugin, before continuing with the vb app.
Chris.
Post date: 7/8/2007 11:51:24 PM
