StructuraFrame Section CutLength
Hello
I'am trying to get a BOM of a assembly with a structuralframe but I do not manage to get the cut length of each section of the frame, I do manage to get the cutlength of the full frame but I am not able to get the seccions (getseccions) to do so with each secction.
What type of objects are going to be in the array that is returning GetSections method.
ForEach oFrame In oAsm.StructuralFrames
Dim i AsInteger = 1
Dim obj AsObject = Nothing
dim sections(0 to 100) as ??????
 oFrame.CutLength(x1, obj)' I got it OK
oFrame.GetSections(i, sections)
Next
Thanks in advance.
Posted by: Xabi Bikuna Losada
Post date: 6/30/2008 3:34:17 AM
RE: StructuraFrame Section CutLength
I almost found the solution
I share it for anybody how just in case want it.
The programing for VB6 and from VB.NET is a bit different
VB6 version ' works ok
  Dim doc As SolidEdgeAssembly.AssemblyDocument
  Dim oframe As SolidEdgeAssembly.StructuralFrame
  Dim namefi As String
  Set doc = objApp.Documents.Open(Filename:=namefi)
  Dim i As Long
  Dim sections(0 To 100) As Long
  Dim length As Double
  Dim objocu As SolidEdgeAssembly.Occurrence
  For Each oframe In doc.StructuralFrames
    Call oframe.GetSections(i, sections)
    For x = 0 To i - 1
      Call oframe.SegmentCutLength(sections(x), length)
      oframe.ReturnOccurrenceForGivenSectionID sectionid:=sections(x), occurrenceasobject:=objocu
    Next
  Next
VB.NET version, the ReturnOccurrenceForGivenSectionID function always returs Nothing
How can it be? Is the .NET interop wrong?
  Dim i As Integer
  Dim sections(0 To 100) As Integer
Dim obj as Object = Nothing
    For x = 0 To i - 1
          oFrame.SegmentCutLength(sections(x), length, obj)
         oFrame.ReturnOccurrenceForGivenSectionID(SectionId:=sections(x), OccurrenceId:=obj, OccurrenceAsObject:=objOcu)
    Next
  Next
Post date: 7/1/2008 12:05:26 AM
Sorry about the previous solution
The VB6 version is working perfectly, and althoug the second (VB.NET) one is quite the same,
the ReturnOccurrenceForGivenSectionID function always returns nothing instead of the occurrence
Does anybody know why can it be? Can someone help me?
Thanks in advance
Post date: 7/1/2008 8:48:43 AM
I have the same problem and I open the PR 1673548.
Delki Trolese
Posted by: Delki Trolese
Post date: 7/14/2008 8:56:34 PM
