Suboccurrences not visible...?
Hi there
This might be a simple task, but i am very much confused how to solve it. And want your help.
I am openning an assembly. It consists of several parts and a subassembly.
All are hide. I am making visible all the stuff. Parts and subassembly is getting visible.
But the suboccurrences(parts in subassembly) are not getting visible.
I am doing following:
Dim oSEApp As SolidEdgeFramework.Application
Dim oSEAsm As SolidEdgeAssembly.AssemblyDocument
Dim oSuboccs As SolidEdgeAssembly.SubOccurrences
Dim objOccs As SolidEdgeAssembly.Occurrences
Dim pc as integer
oSEApp = GetObject(, "SolidEdge.Application")
oSEAsm = oSEApp.Documents.Open(path & "\" & "XYZ.asm")
oSEApp.DisplayAlerts = False
objOccs = oSEAsm.Occurrences
       For pc = 1 To objOccs.Count
           objOccs.Item(pc).Visible = True
       Next
Thanks in Advance
Posted by: Prasad Pawar
Post date: 11/5/2007 8:34:04 PM
RE: Suboccurrences not visible...?
I tried using SubOccurrences properties and methods also. But it didnt worked for me.
Post date: 11/5/2007 8:35:31 PM
is there any option to show all the occurrences (including suboccurrences) of an assembly as we do it manually.
i tried this also:
objOcc = objOccs.Item(pc)
objOcc.Visible = True
If objOcc.Subassembly Then
oSuboccs = objOcc.SubOccurrence
oSuboccs.Item(1).Visible = True
End If
Next
but this is also not working. any suggetion?
Post date: 11/5/2007 10:00:27 PM
Try this:
Dim pc As Integer
Dim x
Set oSEApp = GetObject(, "SolidEdge.Application")
Set oSEAsm = oSEApp.ActiveDocument
Set objOccs = oSEAsm.Occurrences
            If objOccs.Item(pc).Subassembly = True Then
                For x = 1 To objOccs.Item(pc).SubOccurrences.Count
                objOccs.Item(pc).SubOccurrences.Item(x).Visible = True
                Next
            End If
       Next
This works for me ...
Posted by: Bill Ledbetter
Post date: 11/6/2007 10:14:04 AM
hi
it is not working and giving the following error:
Object reference not set to an instance of an object.
Post date: 11/6/2007 5:39:37 PM
Hi prasad,
try to open your asm document as follows:
Override configuration "all parts activated" by adding 2 linefeed separated statements to your asm filename to be opened.
oSEAsm = oSEApp.Documents.Open(path & "\" & "XYZ.asm" & vbLf & "Foobar" & vbLf & "2")
Best regards,
Wolfgang Kunert
www.wksyspro.de
Posted by: Wolfgang Kunert
Post date: 11/6/2007 11:15:51 PM
Sub Main()
' Connect to Solid Edge.
Dim pc As Integer
Dim x
                oSEAsm.Occurrences.Item(pc).Select True
                Next
            End If
       Next
End Sub
I added the line above in BOLD, because I noticed that if the Subassembly wasn't expanded, then the program was failing. Also, check to make sure you have all of your required reference libraries loaded in your project. The only thing I have different from your code is that I am using an assembly already open.
One more thing, how many sub-levels deep are you trying to go?
Post date: 11/7/2007 2:12:50 AM
Hi Bill and Wolfgang Kunert
thanks for your reply. But it is still not working and giving me the same error on the following line:
Only upto 2 levels i am going.(main assembly and a subasm)
Post date: 11/12/2007 3:38:05 PM
This shoul work
Module Module1
Sub main()
objOccs = oSEAsm.Occurrences()
visibleOccurrences(objOccs)
End Sub
Sub visibleOccurrences(ByVal objOccs As SolidEdgeAssembly.Occurrences)
Dim objOcc As SolidEdgeAssembly.Occurrence
Dim subOccs As SolidEdgeAssembly.SubOccurrences
For Each objOcc In objOccs
If objOcc.Subassembly = True Then
subOccs = objOcc.SubOccurrences
visibleSubOccurrences(subOccs)
End If
Next
End Sub
Sub visibleSubOccurrences(ByVal objSubOccs As SolidEdgeAssembly.SubOccurrences)
Dim objSubOcc As SolidEdgeAssembly.SubOccurrence
For Each objSubOcc In objSubOccs
objSubOcc.Visible = True
If objSubOcc.Subassembly = True Then
objSubOccs = objSubOcc.SubOccurrences
visibleSubOccurrences(objSubOccs)
End If
Next
End Sub
End Module
Posted by: Martin Rendler
Post date: 11/12/2007 9:51:59 PM
Hi all,
Thanks for your suggestions. The earlier code is working fine now. I dont know how but i got what i wanted.
Thanks again.
Post date: 11/15/2007 3:52:16 PM
