TabControl
I find the "TabControl" a bit akward at times...
The command:
TabControl1.TabPages(0).Show()
works sometimes, but when it does, it only shows the content of TabPage(0) but does not actually switch the Tab focus , which can stay on Tab 2 for example.
My program, depending on the SE active file type, shows the right Tab, but the command doesn't work.
Should I try to do it differently?
Happy New Year to all
Posted by: Yoland Gagnon
Post date: 1/2/2006 7:01:06 AM
RE: TabControl
Yoland,
Use TabControl.SelectedIndex = x to set the selected tab index.
Posted by: Jason Newell
Post date: 1/3/2006 5:13:58 AM
RE: TabControl
Whoopidouu... works fine now, thx Jason
Post date: 1/3/2006 5:54:26 AM
