TechnicalRequirement Object
I am not seeing how to get the text from the new TechnicalRequirement Object in Draft.
Can anyone confirm that that is possible or not?
LMGi
www.TLMGi.com
Re: TechnicalRequirement Object
Both the help and the Object Browser show just an index property and a delete method.
It does not appear to support extracting the text portion.
Also checked in ST 9, no addition to this API.
