Text in title blocks from Solid Edge into Access database
Hi Jason,
Is it possible to extract the data from title blocks(i.e texts such as project name, end user etc) in solid edge into either an access database or excel spread sheet using VB.NET?? Please help. Thanks, Chinna.
Posted by: chinna raju
Post date: 8/18/2009 5:18:14 PM
RE: Text in title blocks from Solid Edge into Access database
Hi umctigers,
all the data are in Solid Edge Properties. You must read the File Properties (with PropAuto.dll).
Posted by: JR
Post date: 8/18/2009 7:34:45 PM
Hi JR,
Thanks for the reply. I got some text boxes in the title block in my drawing. Is there a way i can extract the textbox values on to a VB Form. I want to save these values from VB into an access database.Can you please give me a sample code. Thanks.
Post date: 8/20/2009 2:47:06 PM
this is a coding for get the value of texbox:
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgeDraft.DraftDocument
Dim objSheet As SolidEdgeDraft.Sheet
Dim objTextBox As SolidEdgeFrameworkSupport.TextBox
Dim objTextBoxes As SolidEdgeFrameworkSupport.TextBoxes
dim sValue as String
'Connect to Solid Edge
objApp = Marshal.GetActiveObject("SolidEdge.Application")
'Get Reference to active document
objDoc = objApp.ActiveDocument
'ex. loop for all sheets
'or only for working section:
'objDraft.Sections.WorkingSection.Sheets
'or for active sheet:
'objSheet = objDraft.ActiveSheet
For each objSheet in objDoc.Sheets
objTextBoxes =objSheet.textboxes
For each objTextBox in objTextBoxes
'the Value:
sValue =objTextbox.Text
Marshal.ReleaseComObject(objTextBox)
objTextBox = Nothing
Next
Marshal.ReleaseComObject(objTextBoxes)
objTextBoxes = Nothing
Marshal.ReleaseComObject(objSheet)
objSheet = Nothing
Next
Marshal.ReleaseComObject(objDoc )
objDoc = Nothing
Marshal.ReleaseComObject(objApp)
objApp = Nothing
Posted by: JR
Post date: 8/20/2009 7:46:22 PM
JR,
Thanks a ton. It worked!!!
Have a great day.
Umctigers
Post date: 8/22/2009 6:03:07 AM
