Textbox justification
I am placing a textbox at certain point using SolidEdgeFrameworkSupport.TextBoxes.Add() ... at the end of a reference line. However, the text shows up starting at that point and continues to the right. (Left Justification).
Is there a way to have the text right justified so that it ends at the point I've given it instead of starting at that point?
Posted by: John Pataki
Post date: 2/23/2009 8:49:52 AM
RE: Textbox justification
Ok.. I had missed the attribute in the object browser... found my own answer... replying to my own question for anyone else who may want to know
SolidEdgeFrameworkSupport.TextBox.Justification()
and requires one of the SolidEdgeFrameworkSupport.TextJustificationConstants
igTextJustifyLeft
igTextJustifyRight
igTextJustifyCenter
igTextJustifyBase
igTextJustifyCap
igTextJustifyBottom
igTextJustifyVCenter
igTextJustifyTop
so my solution:
Dim SETxtBox As SolidEdgeFrameworkSupport.TextBox = SETxtBoxes.Add(label_x, label_y, 0)
SETxtBox.Justification = SolidEdgeFrameworkSupport.TextJustificationConstants.igTextJustifyRight
Post date: 2/23/2009 9:19:37 AM
