The disappearing file property
I'm using Calum's Structured Storage dll to change some file properties.  My program seems to work as intended ... until...
If I right-click on one of the modified files in Windows Explorer, delete the text in "Title" property, then run the program again, the "Title" property is not found in the Summary Information property set.
Has anyone else seen this?
Posted by: Michael Frayser
Post date: 10/9/2008 2:13:07 AM
