Thumbnail of part,assembly,subassembly
I make app for generating BOM from assembly.In my  preview ,i want to show icon from part,assembly and subassembly.
How can i get it with C#?
Thanks.
5 REPLIES 5
Re: Thumbnail of part,assembly,subassembly
take a look at Jason's GitHub project SolidEdge.Community.Reader
The document class in there provides a GetThumbnail() method and may be used as follows:
using (Bitmap bitmap = document.GetThumbnail())
   Console.WriteLine(String.Format("Extracting thumbnail"));
   bitmap.Save(path + ".bmp");
Kind regards,
Wolfgang Kunert - www.wksyspro.de
i've tried to do that,and i get thumbnail of the model in my assembly.
Actually,i have similar app  ,like standart BOM report in SolidEdge.
I want to have a small picture(icon) near Filename.
If it is assembly,it has this picture
If it is a part,this
there exist free tools which can extract icons from exe files (copyrights!?).
I.e. https://www.vlsoftware.net/icons-from-file/
Kind regards,
Hi @Volodymyr
Have a look at my tutorial on extracting the Solid Edge thumbnails of any size:
http://www.surfandcode.in/2014/12/making-of-solid-edge-screen-capture.html
~Tushar
www.CADVertex.com
Thanks for the link.
I'll get all icons,and put them into solution.
