Tip Revision Manager - How to don't break link
I used Revision Manager for copy Parts and a Assembly...
Example
Dim revApp As RevisionManager.Application = CreateObject("RevisionManager.Application")
Dim revDoc As RevisionManager.Document = revApp.Open(path)
Dim revLinks As RevisionManager.LinkedDocuments = revDoc.LinkedDocuments
For item_count As Integer = 1 To revLinks.Count
Dim revLink As RevisionManager.Document = revLinks.Item(item_count)
Dim reName As String = revLink.FullName
reName = reName.Replace(path)
revLink.Copy(path)
Next
revDoc.Copy(path)
revApp.RedefineLinks(SePath, path, , , True)
If openFile.EndsWith(".par") Then
revDoc = revApp.Open(path)
revDoc.Rename(path)
End If
revApp.Quit()
But if the file is Assembly than Occurrences link is broken so I add this code....
revApp.RedefineLinks(path (Before), path (After), files, , True, False)
'path (Before)' is broken link path (I don't know broken link path) with Assembly
'path (After)' is broken link path (Change path) with Assembly
'files' is all files (*.par, *.asm, *.psm, ...)
I used this function files = System.IO.Directory.GetFiles(path)
So I did't broken the link...
I hope many programmer settle the problem to use the function... Smiley Happy
Posted by: gmpark
Post date: 7/3/2013 10:52:03 PM
