Tolerance Sign for igDimDisplayTypeUnitTolerance
I'm working with ST5 and try to read out dimensions out of a drawing.
For the "new" dimensiontype "igDimDisplayTypeUnitTolerance", the tolerance values are stored in PrimaryUpperTolerance and PrimaryLowerTolerance like for the other dimensiontypes. But with no sign. I haven't found a property containing the sign.
Are those properties available in the ST6 / ST7 API?
Best regards
Erich
3 REPLIES 3
Re: Tolerance Sign for igDimDisplayTypeUnitTolerance
Erich,
I am seing a sign in those properties using Spy.
ST6 MP8
LMGi
www.TLMGi.com
Install ST6 MP 8 or ST6 MP2 or higher. This was an issue in the API.
There are no extra properties for the signs.
Regads
JB
SE 2019, VS2017
Thank to all.
My IT department gave me a virtual machine to check my macros against ST6 MP8. All worked as expected. Smiley Happy
The issue that the prefix copier didn't copy the tolerances is also solved. Smiley Very Happy
best regards
Erich
