Topo Tools
Hi Folks:
Sharing a small utility that I developed for personal use in geometry handling - TopoTools:
The buttons on the two tabs are self-explanatory.
Pick Edge/Face: Pick a face or edge in Solid Edge Part and displays the ID.
Highlite Edge/Face: Select a ID from the list and Highlight them in the model.
Refresh IDs: When the model has changed, the new IDs are created and some are deleted.
Create Selectset: of the selected or highlighted face/edge for use with Spy to inspect more properties.
Hope you find this useful too.
~Tushar Suradkar
