Trouble with selected sets cmd
Howdy all
I'm scraching up a bit of code to open a explorer window with the  folder that has the currently selected part selected. Seem's to work fine... well sort of. I can't get the file path of a component that is  selected in a sub assembly (Can't see the wood for the trees). Sorry It's in VB guys as i don't have .net & I'm working in SEv15.
Lookin forward to your replys
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" _
(ByVal hwnd As Long, ByVal lpOperation As String, _
ByVal lpFile As String, ByVal lpParameters As String, _
ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
Private Const SW_NORMAL = 1
Private DocPath As String
Private DocName As String
Private SelectedPart As String
Private SelectedPartTemp As String
Private PartFileLength As Long
Private Sub Form_Load()
Me.Visible = False
Set objse = GetObject(, "SolidEdge.Application")            'Switch to edge
Set objDoc = objse.ActiveDocument
DocName = objDoc.Name
DocPath = objDoc.Path
DocType = Right$(DocName, 3)
If objDoc.SelectSet.Count = 0 Then
 MsgBox "No Component Selected"
 Set objse = Nothing
 Set objDoc = Nothing
End If
SelectedPart = objDoc.SelectSet(1).Name                                                           'find the name
SelectedPart = objDoc.Occurrences(SelectedPart).OccurrenceFileName  '  find the filename of the selected component
'----------Prep up the component info to find the file path-----------
SelectedPartTemp = SelectedPart
PartFileLength = Len(SelectedPart)
For x = PartFileLength To 1 Step -1
    SelectedPartTemp = Mid$(SelectedPart, x, 1)
    If SelectedPartTemp = "\" Then
        Exit For
    End If
Next x
SelectedPart = Left$(SelectedPart, x - 1)
ShellExecute Me.hwnd, vbNullString, _
SelectedPart, vbNullString, _
Set objse = Nothing
End Sub
Posted by: Snow Mackenzie
Post date: 3/23/2008 12:53:24 PM
