Trying to change style in suboccurrence
I am trying to change the color of a part that resides in a subassembly. I can change the colors of the parts in the top assembly and the subassembly in the top assembly, but the occurrences in the subassembly do not change when I set the style property in the ThisAsOccurrence in the item suboccurrences. Any help with what needs to be done to change the color of a suboccurrence part?
Posted by: Richard Sharp
Post date: 12/19/2012 1:15:23 PM
1 REPLY
You may try the method Occurrence.MakeWritable() before changing the color.
Posted by: Wolfgang Kunert
Post date: 12/20/2012 11:03:59 AM
