Two part file are open
I created AddIn application in c# after running the application two part are opening. For given part file I created the document file that working fine.
How to avoid the extra part file.
Thanks in advance.
Posted by: srinivas gowd
Post date: 2/16/2009 12:13:25 AM
RE: Two part file are open
Can't do much to help you without seeing some code. It shouldn't work that way unless your doing something wrong or there is a setup issue.
Posted by: Jason Newell
Post date: 2/17/2009 1:38:13 PM
