Type of linkedDocument in RevisionManager
Hi
I use API of RevisionManager for repaire the broken link of assembly, but in the property "LinkedDocuments" there is also links use in variable (formula)
Is there a property to know it ?
thanhs
Posted by: BONNAUDET eric
Post date: 10/25/2010 9:36:39 PM
RE: Type of linkedDocument in RevisionManager
Hi
the LinkedDocuments property takes a parameter of the enum type LinkTypeOptions (if you're using C# the generated interop will probably have a get_LinkedDocuments method instead of a property).
The enum looks like this:
public enum LinkTypeConstants{    seLinkTypeAll = 0,     seLinkTypeNormal = 1,    seLinkTypeInterpart = 2 }
Use 'Normal' and you should only get the direct links back.
Cheers
Calum
Posted by: Calum McLellan
Post date: 10/26/2010 11:52:07 AM
Very big thanks Calum
My program is in vb.net and i use it like that for filter the linked file in asm
Dim objdoc As RevisionManager.Document
Dim objLinkedDocuments As RevisionManager.LinkedDocuments
objdoc = objApplication.Open(File_name, , False)
objLinkedDocuments = objdoc.LinkedDocuments(RevisionManager.LinkTypeConstants.seLinkTypeNormal)
Post date: 12/16/2010 12:24:26 AM
