Un/check save preview options programmatically
Hi guys,
in ST2 (assuming a doc is open) if you go to Start -->Properties --> File Properties --> then tab 'Preview' there is a checkbox for saving a preview or not. Is it possible to check this option porgrammatically?
regards,
Sibster
Posted by: Seb Sosna
Post date: 9/22/2010 2:41:29 AM
RE: Un/check save preview options programmatically
Hello, here are the following metods:
AssemblyDocument.CreatePreview method
PartDocument.CreatePreview method
SheetMetalDocument.CreatePreview method
WeldmentDocument.CreatePreview method
DraftDocument.CreatePreview method
SolidEdgeDocument.CreatePreview method
Peter
Posted by: Peter Caderas
Post date: 9/22/2010 2:59:47 AM
