Unable to reference fileprp.dll
From Solid Edge File Properties Automation Model:
 ‘You can access the type library for this automation model my referencing fileprp.dll, which is located in the Solid Edge\program directory.’
When I try to reference fileprp.dll in a VB project, the message is ‘Can’t add reference to the file’.
Regsvr32 failed to load the file.
What am I doing wrong?
Posted by: Sanjay Kulkarni
Post date: 7/25/2008 7:43:56 AM
RE: Unable to reference fileprp.dll
PropAuto.dll in C:\Program Files\Solid Edge V??\Program
Posted by: Jason Newell
Post date: 7/27/2008 9:20:05 PM
Thank Jason, for the info.
Your solution worked perfectly.
Post date: 8/3/2008 6:14:55 AM
Post date: 8/3/2008 6:15:24 AM
