Ungrouping of features
Hello all! I am using SolidEdge ST.
I drilled holes and after that I created feature group:
    for(int iHole = 1; iHole
featsArray[iHole - 1] = hole;
featsCount++;
} SolidEdgePart.FeatureGroups featureGroups =
(SolidEdgePart.FeatureGroups) partDoc.Models.Item(1).FeatureGroups; Array aa = (Array) featsArray; SolidEdgePart.FeatureGroup holeFeatureGroup =
featureGroups.AddFeatureGroupsBySet(featsCount, ref aa); holeFeatureGroup.Name = "aa"; Next time I want to add some holes to this group, but - I cannot find method "addFeature"
- In "models" count of featureGroups is equal to 0
- I decided to delete group first and create new with all holes Finally I was successful to find it in EdgebarFeatures so I wrote
SolidEdgePart.EdgebarFeatures edgeBarFeats = (SolidEdgePart.EdgebarFeatures)
partDoc.DesignEdgebarFeatures; SolidEdgePart.FeatureGroup featureGroup = null; for(int iFeat = 1; iFeat
try
featureGroup = (SolidEdgePart.FeatureGroup)edgeBarFeats.Item(iFeat);
catch
continue;
} if(featureGroup.Name.CompareTo("aa") == 0)
featureGroup.Ungroup();
}   But It goes through ungrouping but does nothing. When I try to delete group instead of ungrouping featureGroup.Delete(); it finishes with error. But I expect that I need only ungrouping because deleting removes also holes. Should I use some special update for ungrouping? Or am I in completely bad way? Thanks and Regards, Jara
Posted by: Jara Ctverak
Post date: 10/20/2009 4:09:12 AM
RE: Ungrouping of features
Hello All!
I still don't know how to ungroup but I finally found out that reorder can help me to add hole to existing group which is sufficient to me.
Jara
Post date: 10/20/2009 10:37:13 PM
